spec for 300 pounds
16 Dec 2005
Halifax W'Yorkshire
ok a friend needs a whole tower everything in it. hdd's, the case, the lot.
allso 300 pounds has to include a oporating system.
if any one would like to put shopping list of 300 pounds here, please do so, thanks :)
thanks for replying so quickly, i forgot to add, she wants to be able to play Counter-strike:source on it with reasonable quality. her system she has now is on motherboard graphics and its nearly dieing, its a windows 98.
any other basket ideas? thanks
Can we say that the IDE PATA HDD is reuseable? The case? CD ROM?
Can they play games under Linux - allowing us to ignore Windows in our specs? Wink Wink.
nope has to be a whole lot. well actually could exclude the case and hard drive i guess and the dvd drives
just need a mobo cpu oporating system, psu, ram, gfx card :)
This is a suggestion.
E4300 around 100
Asrock Dual VSTA 35 (OCUK DOES NOT STOCK THEM, so you will have to look on your own)
GPU 7600GT 80 or so
If the ram is DDR ram is here current PC, use that in the motherboard, it supports DDR1 and DDR2 ram.
Use the rest for her PSU/OS.
*EDIT*
Option 2
Asus bare bones 70
AM2 Dual Core 3800 64
1GB DDR2 GEIL 70
7600 GT 70
THen you need the OS. That is the best I can do. YOU couod get the GPU (like an x800XT or something) from MM, or auction.
