spec for £700 base unit needed.. system builders here please!
19 Jan 2005
Legoland
Right I have my mates 700 bucks to play with, he basically need to build a new base unit, case and all. His old pc is 4 years old, about time for an update, he doesn't need monitor or owt else, just the base unit. Spec me a budget conroe please, looking for 2 gig ram and reasonable o/c potential. He plays games a fair bit so best bang for buck folks.. TY
You might want to check the compatability of the Ram with the motherboard(there is a big thread in the Motherboards forum and I think it is fine but I can't remember offhand), other than that you have a collection of good solid parts with a fair bit of overclocking potential.
MB-061-GI Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI)
£89.99 £89.99
CP-135-IN Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
£99.99 £99.99
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£14.99 £14.99
MY-072-OC OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) (MY-072-OC)
£159.99 £159.99
CA-067-AN Antec NSK6500 Super Midi Tower Case - 430W PSU (CA
£58.99 £58.99
GX-042-OK OcUK GeForce 7900 GS 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GX-042-OK)
£97.99 £97.99
CD-042-NE NEC AD5170 18x18 DVD±RW Dual Layer ReWriter (Silver) - OEM (CD-042-NE)
£18.99 £18.99
HD-079-SE Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE)
£51.99 £51.99
Subtotal £592.92
VAT £103.77
Total £696.69
The PSU is fine, it is a modern PSU from a good brand so will easily cope although for very heavy overclocks you may need to consider something else.
As for other combinations I'd wait a while and see what anyone else can come up with. :)
