Spec for £700
7 Nov 2006
Stockton on Tees
How Do!
Spec needed for a pc for the price of no more than £700
Whats not needed:-
Soundcard
Case
Hard Drives
OS
Case Fans
Monitor
Required for:
All round usage (Multimedia Centre....watching movies/playing music, games, CAD).
Ideally something that clocks like hell!
Desirables:
Ideally want it to be a quiet running system
Thank You
This is a bit under the budget but should allow for a good bit of overclocking and would be a good system even at stock speeds.
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM £101.99
(£119.84) £101.99
(£119.84)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) £61.99
(£72.84) £61.99
(£72.84)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £69.99
(£82.24) £69.99
(£82.24)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £139.99
(£164.49) £139.99
(£164.49)
Connect3D ATI Radeon X1950 XT 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £137.99
(£162.14) £137.99
(£162.14)
Pioneer DVR-111BK 16x16 DVD±RW Dual Layer ReWriter - (Black) OEM £18.99
(£22.31) £18.99
(£22.31)
Tuniq Tower 120 CPU Cooler £28.99
(£34.06) £28.99
(£34.06)
Sub Total : £559.93
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £9.95
Vat : £99.73
Total : £669.61
grab an E4300 instead, with the higher mulitplyer you wont have to worry about stretching the ram too far. Also save you a couple more quid and then grab the best x1950 your budget will allow for :)
