Spec for £840 :)
2 May 2004
Hi,
I just wondered what's the best I can get for £840?
Preferably 500GB+ HDD, 8800GTX, 2GB RAM (MUST!!)
I need CPU, graphic card, hard drive, motherboard, PSU, RAM, case.
It would also need to be future proof please. (e.g. quad core capable, a nice lot of SATA ports for RAID, SATA DVD drives etc)
EDIT
Oh, and I don't plan to overclock, but I'd like the option to be there please.
Thanks,
Craig.
For £840 forget quad core, Your very lucky to get a e6600 , 500gb hdd and a gtx for £840.
Im doing a spec now.. Bare with me
Nooooo I don't want quad core to start with, just a motherboard that could handle it for future upgrades (if possible) :)
Thanks,
Craig.
Jay123 said:
£840 the MAX?
At the moment, yeah.
I quickly put together one now: Gigabyte DS3, 2GB Corsair XMS, 500GB HDD, 8800GTX, 600W Seasonic for £826. It was just a quick one so they might not be best components. (That's why I asked here :D)
I know it's £15 over, but it gives you a P35 motherboard with DDR2&3
support for future overclocking.
http://i50.photobucket.com/albums/f305/mrbrown1080/840spec.jpg[/IMG[/QUOTE]
Nice, I like the DDR2/DDR3 compatible board :)
The case is a bit cheap for me, but I guess I could go for a case like that to start & buy a better one in the future :)
EDIT
Ooh, I see you just changed it :)
Thanks,
Craig.
The Spec is okay. But you also got to think about the cpu will bottleneck the cpu . The cpu you spec is very low (he isnt going to overclock) and it will course problems.
Heres mine :
Guys im not being funny here. The Processors are TOO LOW for the gtx. He isnt going to overclock . Theres going to be a bottleneck on the Graphics card.
Please can somebody put it in there heads ?
Core 2 Duo E4400 Will not cut the butter ! 800FSB will do nothing for his machine or the GTX ... IF you was going for the E4400 then go for a GTS version of the 8800
Yes i know pal, he also said under £840 and a GTX, all we can do is give him what he wants and we can advise him saying increase your budget for a better CPU or get the GTS 640 so your CPU doesnt bottleneck your GFX Card which we've done.
True, But i think he wont be happy if we gave him the low range cpu with the gtx .. I agree, Give him what he wants :p
Ok guys, I give you permission to go to £900!
I got this with £889:
Intel Core 2 Duo E6600, Socket 775, 2.4 GHz, 1066MHz FSB, Conroe Core, 4MB Cache, Retail
768Mb Leadtek 8800GTX PCI-E (x16), Mem 1800 MHz, GPU 575 MHz, 128 Streams, 2 x Dual Link DVI HDTV
500 Gb Seagate ST3500630AS Barracuda 7200.10, SATA300, 7200 rpm, 16MB Cache, 8.5 ms, NCQ
2GB (2x1GB) CorsairTwinX XMS2, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 4-4-4-12, EPP
Gigabyte GA 965P-DS3P, iP965, S775, PCI-E (x16), DDR2 533/667/800, SATA II, ATX
Akasa Eclipse-62 Midi Tower Case - Hi-End w/o PSU
520W Corsair HX Series Modular PSU, ATX, EPS12V, whisper quiet, 5 year warranty
Some stuff may be improved by different manufacturers/components (I'm not sure) :)
Thanks,
Craig.
Thanks,
Craig.
You Havent included a dvd-re writer. do you need an os ?
To be honest your better with a GTS ( My Opinion )
Let me know
Let me know
I've got a DVD drive I can use which will do for now, I also have a spare XP :)
The DVD drive will be upgrading to a burner/reader after I've got the PC :)
Your basket
Product Name Qty Price Line Total
Samsung SpinPoint T HD501LJ 500GB SATA-II 16MB Cache - OEM £58.99
(£69.31) £58.99
(£69.31)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £61.99
(£72.84) £61.99
(£72.84)
EVGA GeForce 8800 GTS SuperClocked 640MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (640-P2-E825-AR) £229.99
(£270.24) £229.99
(£270.24)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) £61.99
(£72.84) £61.99
(£72.84)
Antec P180 Advanced Super Midi Tower Case - No PSU (Black) £68.99
(£81.06) £68.99
(£81.06)
Samsung SH-183LBEBN 18x18 DVD±RW Dual Layer Serial ATA Lightscribe ReWriter (Black) - OEM £16.99
(£19.96) £16.99
(£19.96)
Intel Core 2 Duo E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail £125.99
(£148.04) £125.99
(£148.04)
Microsoft Windows Vista Home Basic 32-Bit Edition DVD - OEM - 1Pk (66G-00576) £47.99
(£56.39) £47.99
(£56.39)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £59.99
(£70.49) £59.99
(£70.49)
Sub Total : £732.91
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £14.95
VAT is being charged at 17.5% VAT : £130.88
Total : £878.74
Jay123 said:
Your basket
(£69.31) £58.99
(£69.31)
(£72.84) £61.99
(£72.84)
(£270.24) £229.99
(£270.24)
(£72.84) £61.99
(£72.84)
(£81.06) £68.99
(£81.06)
(£19.96) £16.99
(£19.96)
(£148.04) £125.99
(£148.04)
(£56.39) £47.99
(£56.39)
(£70.49) £59.99
(£70.49)
Sub Total : £732.91
Total : £878.74
Looks good, but I'm not so sure about the GTS. I've heard the GTX series are quite a bit better?
