Evening/Morning All,
My dad's decided it's time to upgrade his PC, it's starting to become a little sluggish with outlook 2010. However it's been about three years since I last looked inside a PC or at components!
His current spec is fairly old, I bought the mobo and gfx card in 2005!
A8V Deluxe
64 X2 Dual Core 3800+ (@2500Mhz)
Arctic Cooling Freezer 64 Pro CPU
OCZ 2x1GB 3200 CL 3-4-4-8 Dual Value Kit
Asus ATI Radeon X800 XT PE Platinum 256MB (AGP)
HX520 PSU
What would you suggest for simply excel, word and internet? He's not planning on gaming but I can't decide if the intel built in GPU is a gimmick. Comments?
I haven't been set a budget so far however, with such low requirements I would have thought £200-300.
Thanks
James
A8V Deluxe
HX520 PSU
Thanks
James
) so pretty much anything modern CPU-wise with 4GB of ram should do.
