Spec for encoding
3 Apr 2003
Hi guys,
Friend of mine is looking to make some amateur movies and generally playing around with video editing software and is finding his old pc cant cut it for encoding. Is having to leave it on overnight for minimal tasks and would like to upgrade to a quad core to speed this up.
He has plenty of HDD, PSU, peripherals. But needs the core components, mobo ram, cpu, sound, gfx.
This is purely for encoding video so i am not sure that would even need a seperate audio/gfx solution? But as i know zero about video editing and encoding i thought i would ask here where someone might actually know.
So could people please spec me the core components for a machine purely to be used for video editing and encoding. Cheers :)
What is the rough budget here? From what I know when encoding the graphics card isn't terribly important since it relies largely on pure CPU power. Does the video editing software that your friend uses utilise quad core?
I honestly dont know, but he is fairly sure the software he uses could utilise 4 cores so thats what he wants.
There is no set budget, just wants it as cheap as poss but good performance. I would imagine just for core components anything up to about 300 would be fine. Though cheaper the better if doesnt compromise too badly on performance which would defeat the purpose of an upgrade lol.
This might do then, the onboard graphics should be more than sufficient for the uses suggested. I don't know if you need the soundcard as such so you could perhaps drop it and decide later.
Asus P5E-VM HDMI Intel G35 Micro-ATX (Socket 775) PCI-Express DDR2 Motherboard £63.99
(£75.19) £63.99
(£75.19)
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail £99.99
(£117.49) £99.99
(£117.49)
GeIL 4GB (2x2GB) PC2-6400C4 800MHz Black Dragon DDR2 Dual Channel Kit (GB24GB6400C4DC) £52.99
(£62.26) £52.99
(£62.26)
Asus Xonar DX 7.1 PCI-Express Sound Card (Low Profile Compatible) - Retail £49.99
(£58.74) £49.99
(£58.74)
Sub Total : £266.96
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.25
VAT is being charged at 17.5% VAT : £48.16
Total : £323.37
