Spec for Friend
12 Jan 2005
Bristol Massive
Morning peeps, putting a build together for my Friend. He has around £900-950 to spend. Any changes you would make to the spec below?
-Scythe Infinity Heatpipe CPU Cooler
-NEC AD7170S Serial ATA 18x18 DVD±RW Dual Layer ReWriter (Black) - OEM
-Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM
-EVGA GeForce 8800 GTS SuperClocked 320MB GDDR3 HDTV/Dual DVI (PCI-Express)
-OCZ 2GB (2 x 1GB) PC2-6400 Dual Channel Platinum Revision 2 XTC Series
-Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
-Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail
-Lian-Li PC-7 PLUS Aluminium Midi-Tower Case - Black
-Corsair HX 520W ATX2.2 Modular SLI Compliant PSU
-Microsoft Windows XP Home Edition inc. SP2 - OEM - 1Pk
Total £866.97
Will_3rd said:
Looks good, might want to change the HSF to the Tuniq and the OS to XP Professional
Will the Tuniq fit ok into the Lian-Li case, was'nt 100% sure it would?
Regarding the OS, ages ago his pc broke he did'nt have much of a clue so he paid someone to reformat and install windows xp pro.
A few day's later he tried to do a windows update and it turned out this guy has put a pirate copy on and still charged him £60 for it. He ended up having to shell out £90 to microsoft for a legal copy etc.
This pc that has Xp pro on is now a total mess, would I be able to transfer that OS to this PC that i'm building.? Will I have to contact Microsoft or something?
masslac said:
Your friend was conned. Buy Vista.
He was quite upset about this, he knows this guy's address he even has an ad in the yellow pages lol. I may ring him up and get him what for.
Vista it is then, just go for the basic one?
