- 5 Nov 2020
Hello guys.
Last time I custom built a PC was around 15 years ago, so I'm a little behind to the new tech to say the least
My new PC will be focused on game developing and 3D modeling, not much gaming itself in fact, but of course I will test my games and eventually play some other ones.
My budget is around 2.500 euros(I live in Holland) but I'm willing to go a bit higher if necessary, my goal is the best performance within that price range with the lowest noise possible, definitely don't want all those fans/memory/cables that glows inside the tower
This is what I'm thinking about:
- GeForce RTX 3080.
- 32gb DDR4 (probably will expand to 64gb in the future).
- 2x 1TB SSD.
- 850w power supply.
- For the processor I have no preference between AMD or Intel, but following the Unreal Engine specs they recommend Xeon, what do you guys think about it ? Xeon is a big step in price, not sure if in real life it will be that much of a difference from a i9 for example.
- Motherboard will depend on the processor.
As I mentioned, noise is a big factor for me, should I go for water cooling for quietness ? I will not overclock, so if I can keep it quiet with fans, I prefer.
What do you guys think ?
Cheers!
- GeForce RTX 3080.
- 2x 1TB SSD.
Cheers!
