- 5 Sep 2008
Hi,
Been looking at some specs for a while now, nothing I have seen exactly fits me so it would be great help if someone can recommend me some specs.
Firstly I just want Tower specs, other peripherals don’t matter, no OS too.
I want to do both Gaming and use of 3D software (3Ds Max2009)
Should be able to run today’s games and at least next years games smoothly.
The most important factor for me is a good buy; an example of this would be something like an extra £50 to buff up a 512mb graphics card to 1024.
A bad buy would be an extra £50 for a CPU cooler that makes little difference to temps.
The “Intel Core 2 Quad Pro Q6600 2.40GHz Guaranteed to run at 3.30GHZ” for example looks like great buy but I’m not sure if I want to be OCing if the CPU will end up dying after a year or 2 , and without OCing the Buy seems pretty average.
To be precise, I’m not buying to show off my specs, I’m just trying to buy the best for what I need while saving as much as possible.
I sound a little picky, but any help will be greatly appreciated,
Budget about £700, can stretch lower or higher.
Thanks in advance for any recommendations!
