spec for mate
12 Sep 2005
Bristol-ish
Hi just woundering if u can spec up a pc for a mate. Budget about £700, he wants dual monitors probably crt and he has hdd already. would be use mostly for gaming and programing.
o/cing at all? what size one monitors? is the hd sata or what? do you need keyboard, mouse etc?
Does your mate have anything already or does he need absolutely everything including dual monitors, all peripherals and software? If so he won't be able to get any CRT monitors from OcUK as they don't appear to stock any now, that leaves TFT monitors so to get two you have taken £200 or more out of the budget immediately so I suspect he'd be better starting off with one monitor and getting a decent system then adding another monitor when he has more cash.
he will need windows but that has been taken out of the budget and kb and mouse aint an issue but appart from that he will need everything, size of the monitor doesnt matter but he would like it to run 1600x.. res if possible. I did recommend that he doesnt get 2 monitors atm, could you do a spec for both dual and single moitors so i can show him the difference.
hard drives are ata as he has 4 250gb so doesnt want to really change them to sata, so a sata dvd drive would probably be needed.
Thanks
This might be suitable as the dual monitor system however your mate will need to buy an additional PCI ATA/IDE controller card since pretty much all socket 775 motherboards only come with one IDE port(i.e. 2 drives). Also note that this case is out of stock but that should be only temporary.
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) £13.99
(£16.44) £13.99
(£16.44)
Asrock Conroe945G-DVI (Socket 775) PCI-Express DDR2 Motherboard £44.99
(£52.86) £44.99
(£52.86)
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM £93.99
(£110.44) £93.99
(£110.44)
Corsair 1GB DDR2 Value Select PC5300 Dual Channel Kit (2x512MB) (VS1GBKIT667D2) ( £72.99
(£85.76) £72.99
(£85.76)
Antec NSK6500 Super Midi Tower Case - 430W PSU (CA £58.99
(£69.31) £58.99
(£69.31)
OcUK Value Hanns-G HC174D 17" LCD Monitor - Silver/Black £99.99
(£117.49) £199.98
(£234.98)
Samsung SH-W183 18x18 DVD±RW Serial ATA Dual Layer ReWriter (Black) - OEM £19.99
(£23.49) £19.99
(£23.49)
Leadtek GeForce 7600 GS SILENT 256MB DDR2 TV-Out/DVI (PCI-Express) - Retail £63.99
(£75.19) £63.99
(£75.19)
Sub Total : £568.91
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £12.95
Vat : £101.83
Total : £683.69
If going for a single monitor then this is just over the budget but includes 2gb Ram, a better motherboard for overclocking and a much better graphics card.
(£16.44) £13.99
(£16.44)
(£110.44) £93.99
(£110.44)
(£69.31) £58.99
(£69.31)
(£117.49) £99.99
(£117.49)
(£23.49) £19.99
(£23.49)
GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) £129.99
(£152.74) £129.99
(£152.74)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £84.99
(£99.86) £84.99
(£99.86)
OcUK GeForce 7900 GS 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail £99.99
(£117.49) £99.99
(£117.49)
Sub Total : £601.92
(This can be changed during checkout) Shipping : £10.95
Vat : £107.25
Total : £720.12
Third option would be a single monitor capable of 1680x1050, you still have 2gb Ram but a slightly worse graphics card than in both and you are back to the mATX motherboard so limited overclocking options.
Viewsonic VA2012W-2 20" Widescreen LCD Monitor - Silver/Black £184.99
(£217.36) £184.99
(£217.36)
(£16.44) £13.99
(£16.44)
(£110.44) £93.99
(£110.44)
(£69.31) £58.99
(£69.31)
(£23.49) £19.99
(£23.49)
(£152.74) £129.99
(£152.74)
(£52.86) £44.99
(£52.86)
OcUK GeForce 7300 GT 256MB GDDR3 HDTV/DVI (PCI-Express) - Retail £49.99
(£58.74) £49.99
(£58.74)
Sub Total : £596.92
Vat : £106.73
Total : £716.60
