Well this spec is for a friend but it has to be 550 all in with postage and packaging, this is for the base unit and all the bits inside, basically it has to run games fast and have no problems with alt tabbing between them so far i have came up with this but just want to know if anyone can do better or which items i should change, and if all the items i have stated are compatible like motherboard/cpu ect/gfx card
Gigabyte GA-P35-DS3R (Socket 775) PCI-Express DDR2 Motherboard
GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC
Intel Core 2 Duo E2180 "LGA775 Conroe" 2.00GHz (800FSB) - Retail
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK)
Western Digital Caviar Special Edition 160GB SATA-II 8MB Cache - OEM (WD1600AAJS)
Gigabyte GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (GV-NX88T512H-B)
LG GDR-H30NBL 16x DVD-ROM (Black) - OEM
Akasa AK-ZEN-01-BK Zen Black Case - No PSU
on the mobo it also says Supports DDR2 1066* memory does that mean it will take upto 1066 mhz ram? so the Geil i have stated would be fine?
and Also the motherboards i ask this question a lot but still a Dual Core processor 2 cores would be fine in it?
Thanks
Thanks
