I'm speccing a bit of an upgrade to my current setup and going the mATX route since I don't have much space to put it. So far I have come up with:
Case:
Antec Black Mini P180 mATX Case
CPU:
Intel Core 2 Quad Q6600 (overclocked to 3Ghz)
Motherboard:
Gigabyte GA-G33M-DS2R mATX Motherboard
CPU Cooler:
Arctic Cooling Freezer 7 Pro
Memory:
OCZ 2GB (2x1GB) PC2-6400C4
GFX Card:
EVGA GeForce 8800 GT 512MB KO GDDR3
PSU:
Seasonic 500W S12 PSU (from current setup)
Hard Drives:
Hitachi T7K250 (from current setup)
WD Raptor 36GB (from current setup)
Which for the new bits and pieces comes to about £500 total.
I'd welcome any suggestions on the above, but I also have a few questions:
1) I'm planning to reuse my Seasonic 500W S12 power supply from a couple of years ago, will it deal ok with this setup? Is it generally a bad idea to put in a used PSU to a new setup?
2) I have about £100 left in my budget but not sure what this should go on.
I don't want to go for SLi, and suspect my new case might not have enough space for some of the more powerful GFX cards (heat might also be an issue). Also I want to stick with mATX.
What should I spend this on to get the most out of my new setup (which will mainly be for gaming)?
Case:
CPU:
Motherboard:
CPU Cooler:
Memory:
GFX Card:
PSU:
Hard Drives:
