Spec help please
15 Nov 2005
Peterborough
I know I know, yet another spec request! :rolleyes: :p But you guys are so good at it and there is soooo much to choose from!
I have an £1100 budget, possibly able to push £1200 (with abit of crawling to the wife!)
I believe Conroe is the current way to go (last time I asked it was an Opteron) and I want the HIS 1900XT 512Mb Graphics card. Not bothered about XFIRE but may want to Overclock. Also needs to be quiet! Apart from that I will leave upto you guys!
*EDIT* Don't need monitor, mouse, keyboad, soundcard
Thanks a lot
AB
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM (CP-135-IN)
Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE) x 2
HIS ATI Radeon X1900 ICEQ3 SILENT Heatpipe ***Crossfire Edition*** 512MB GDDR3 (PCI-Express) - Retail (GX-056-HT)
GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL)
NEC ND4570 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-030-NE)
Scythe Ninja Plus Heatpipe CPU Cooler (Socket 478, 754, 939, 940, LGA755) (HS-003-SY)
Creative Sound Blaster X-Fi Xtreme Music - Retail (SC-034-CL)
Lian-Li PC-7 PLUS Black Aluminium Midi-Tower Case (No PSU) (CA-054-LL)
FSP Sparkle FX600-GLN Epsilon 600W ATX2.0 PSU (CA-002-SK)
Subtotal £949.57
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £10.95
VAT £168.10
Total £1,128.62
u didnt say if u where gonna re-use any parts u have, if r, can deduct that from price.
HS-003-SY Scythe Ninja Plus Heatpipe CPU Cooler (Socket 478, 754, 939, 940, LGA755) (HS-003-SY) 1
£31.95 £31.95
HD-079-SE Seagate Barracuda 7200.10 250GB ST3250620AS SATA-II 16MB Cache - OEM (HD-079-SE) 1
£49.95 £49.95
MB-061-GI Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard (MB-061-GI) 1
£91.99 £91.99
CA-024-EN Enermax Liberty 620W ELT620AWT ATX2.2 Modular SLI Compliant PSU (CA-024-EN) 1
£89.99 £89.99
CA-038-LL Lian-Li PC-7 PLUS Silver Aluminium Midi-Tower Case (No PSU) (CA-038-LL) 1
£47.95 £47.95
CD-037-NE NEC ND3550 16x16 DVD±RW Dual Layer ReWriter (Silver) - OEM (CD-037-NE) 1
£19.95 £19.95
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN) 1
£209.99 £209.99
MY-058-GL GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL) 1
£124.95 £124.95
HD-095-WD Western Digital Raptor 36GB WD360ADFD 10,000RPM SATA 16MB Cache - OEM (HD-095-WD) 1
£66.95 £66.95
GX-053-HT HIS ATI Radeon X1900 XT ICEQ 3 SILENT Heatpipe 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-053-HT) 1
£199.99 £199.99
Subtotal £933.66
VAT £163.40
Total £1,097.06
edit: changed the spec, added the wrong gfx card.
wow you guys are quick...thanks for your responses.
You have both gone for the Scythe Ninja Plus Heatpipe CPU Cooler. Will I also need the thermal paste stuff?
Will I need extra fans for additional cooling/air flow or will what you have suggested suffice?
Are these quiet options?
ninja come with 120mm fan, case comes with 2 x 120mm fans so plenty overall cooling, deduct £55 from my setup, as just noticed u dont need sound card :)
with this setup would reckon u would get 3.2 to 3.5 , very fast pc :)
also on that asus board they working on a bios 2 unlock multi (downWords), thread about it on antech, very impressive read with this board & 6300 core 2 chip :)
The cooler should come with paste applied but i'd buy some AS5 incase you want to clean the hsf later on.
The scythe ninja is very quiet, it can run fanless but if overclocking you shold use a fan. Maybe buy a Akasa amber 120mm ultra silence fan if your after quietness.
Thats what I was hoping for :)
lol - nope you lost me there. If you are referring to overclocking, then I have no experience with it and will probably dabble - very slowly and carefully!
Is there much difference between the 6300 and 6600? Both have been specced to me.
