- 6 Jan 2013
- Rollergirl
I'm looking to add a custom loop to the project log in my signature.
So, building into an Air540 case, and looking to cool an i5 4670k CPU and Gigabyte GTX670 N670OC-2gb Windforce GPU.
Ideally I want a pump and res combo, mounted where this guy has placed his...
http://forums.overclockers.co.uk/showthread.php?p=24620005#post24620005
I would like to have coloured tubing (orange). 360 rad at the front, 240 rad at the top.
This is my first loop, so need help choosing all parts... although I don't need any help choosing fans.
Thanks in advance for any help. Will update thread with parts list as decisions are made!
Parts List:
YOUR BASKET
1 x EK Water Blocks EK-D5 Vario X-RES 100 (incl. pump) £105.95
1 x EK Water Blocks EK-Supremacy Clean CSQ - Nickel £52.99
1 x EK Water Blocks EK-CoolStream PE 360 (Triple) £49.99
1 x EK Water Blocks EK-CoolStream PE 240 (Dual) £39.95
3 x Monsoon 13/10mm (ID 3/8 OD 1/2) Free Center Compression Fitting Six Pack - Orange £27.95 (£83.85)
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £25.99
1 x PrimoChill PrimoFlex Advanced LRT 12.7 / 9.5mm - Pearl UV Orange RETAIL 3m £16.99
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Single Pack (CO-9050005-WW) £13.99
1 x XSPC LCD Temperature Sensor (Orange) V2 + G1/4" Inline Sensor £8.99
4 x Monsoon 13/10mm (OD 1/2) Rotary 45° - Orange £6.95 (£27.80)
1 x Monsoon 13/10mm (OD 1/2) Rotary 90° - Orange £6.49
1 x Aqua Computer Ball Valve Female Thread G 1/4 without Fittings £5.99
1 x Mayhems Fine Silver Kill Coil £4.50
1 x XSPC G1/4" T Fitting (Black Chrome) £3.95
1 x EK Water Blocks EK-PLUG Fitting G1/4 £1.30
1 x XSPC PSU Bridging Connector (24 Pin) £1.30
Total : £459.60 (includes shipping : £8.00).
Parts List:
YOUR BASKET
