well a hsf which would be another £20.
Hello spec me a pc please, its for a mate. I have £1000 to spend. He isnt a gamer so dont really require a 8800gtx.
Monitor, Keyboard, Mouse is needed. That RAM is pointless at that price. The 620W is not 100% necessary, due to not having a 8800GTX.
. thought it said keyboard etc not needed lol.
Whoops, forgot a keyboard.
Editing...
How's that look?
thats a good spec, but the RAM is waaaay overkill. GeIL 2GB would be more than good enough for a none gaming machine.![]()
but again we really need a bit more info
I always reduce the width of the window until the scroll bar appears at the bottom. This indicates that the column is as narrow as it's going to get. This is helpful for readers with smaller monitors as its less likely to break the page by widening the post too much. I too use Screengrab. This saves the selection as a .png. I use the Gimp to save the .png as a lossless .gif for a little smaller file size. This is helpful for readers who have slower Internet connections. I already feel bad for making them wait for an image to load rather than plain text so this meets them halfway.how do you get speck with that quality? using any special proggies. i am using screengrab extension for firefox
This process means that the image is represented as it appears on screen without ever being subject to lossy jpeg compression or scaling to reduce the overall size.
I always reduce the width of the window until the scroll bar appears at the bottom. This indicates that the column is as narrow as it's going to get. This is helpful for readers with smaller monitors as its less likely to break the page by widening the post too much. I too use Screengrab. This saves the selection as a .png. I use the Gimp to save the .png as a lossless .gif for a little smaller file size. This is helpful for readers who have slower Internet connections. I already feel bad for making them wait for an image to load rather than plain text so this meets them halfway.This process means that the image is represented as it appears on screen without ever being subject to lossy jpeg compression or scaling to reduce the overall size.
For carts that are taller than my screen I have screengrab save the whole page then I crop it using the Gimp.![]()
Nice cable management and nice looking case!
