Spec Me 27" 1440p 144hz VA Panel Monitor?
  • Thread starter Thread starter IC3
  • Start date Start date
IC3
IC3
3 Dec 2011
I'm searching for 27inch 2560x1440 144hz monitor on a VA Panel, I believe this will probably be the best overall package for the budget I set to spend. I just want a monitor with height adjustment, better colours/blacks and without massively noticeable ghosting. I guess the adjustability isn't that much of an issue if the monitor is worth considering, I can just get a monitor arm.
- £300 (Lower the better, 70% use will be office work and 30% Competitive FPS Games)
I have purchased a ultrawide screen Iiyama G-MASTER GB3461WQSU-B1 before, however the horrendous IPS Glow and size of the monitor put me off it.
