Spec me 2x 120mm GPU Fans and paste
16 Feb 2012
My accelero pro 2 fans have gone broken.
I need 2x new 120mm fans that I will strap on heatsink
I also need thermal paste for inbetween chip and heatsink
I have some as ceramique that i used for my cpu can i just use this or is it better better gpu paste
Thanks
I wouldn't want to be messing around trying to adapt standard 120mm fans to fit a graphics cooler on an expensive card. You can buy a new Accelero Twin Turbo Pro online for £25 and this would be a much better option.
Thermal paste is thermal paste use what you have and put the money you were going to spend on "gpu paste" towards a new heatsink.
If you have to go with buying fans then my first option would be to look at the one that Arctic Cooling have developed for their passive coolers - http://www.overclockers.co.uk/showproduct.php?prodid=HS-063-AR
