Spec me £400
6 Oct 2007
Liverpool
Approx. £400 can be little over or under...
i keep getting about £500 trying to find best bang for buck among each component.
thanks!
YOUR BASKET
1 x OcUK Value GeForce GTX 460 "Green Edition" 768MB GDDR5 PCI-Express Graphics Card £99.98
1 x Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £91.99
1 x MSI H61M-E33 Intel H61 (Socket 1155) DDR3 Motherboard **B3 REVISION** *WITH FREE MSI GRENADE* £46.99
1 x BeQuiet Pure Power L7 530W '80 Plus' Power Supply £44.99
1 x Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £33.98
1 x Xigmatek Midgard Midi Tower Case - White £29.99
1 x Corsair Value 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low Voltage Dual-Channel Kit £23.98
1 x LG GH22NS70 22x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £401.50 (includes shipping : £10.50).
It's only a tower with no OS. Shame you missed the OcUK 460 OC deal. If you can stretch, with free delivery... Or a 5830 if you can find one. There is a B-grade XFX 6850, maybe worth keeping an eye on it.
Nice spec, and if you could stretch, swap out the Hard Drive for this.
http://www.overclockers.co.uk/showproduct.php?prodid=SW-000-OP&groupid=33&catid=1963&subcat=
Also if your not keen on the White Case, get the black version.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-XG&groupid=701&catid=7&subcat=
Similar look, and is black so isn't in your face as much.
Oh, didnt notice his signature :p
I'd keep your current system, and just get a new GFX card, sell on your 5770 in MM and get a better GFX card as Olivier has said.
Also with £400, get a nice small SSD, or treat yourself to a new monitor :)
haha nope this is not my pc... i will be upgrading mine soon though :) and a SSD is a must!!
if the rig for the above is going to be used for gaming is the buget Ram ok ? i went for the OcZ.
SSD is a must for yourself? or within the spec Olivier has posted? :confused:
And i think it should be, its just Low Voltage, works fine in my brothers computer with a 5850 and the same i3-2100 :)
For myself at a later date :) will be just for OS and Starcraft :cool:
ok i think the budget just went up a little more but am still way over, this is the rig i have spec myself at the minute.
Sapphire ATI Radeon HD 6950 1024MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 Game £179.99
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £83.99
Asus M5A78L-M/USB3 AMD 760G (Socket AM3+) DDR3 Motherboard Motherboard £54.98
OCZ ModXStream Pro 500w Silent SLI Certified Modular Power Supply £47.99
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) £31.99
Cooler Master Elite 330 Midi Tower Case - Black Cooler Master Elite 330 Midi Tower Case - Black £28.99
Sony Optiarc AD-7260S 24x DVD±RW SATA Lightscribe ReWriter (Black) - OEM Sony Optiarc AD-7260S 24x DVD±RW SATA Lightscribe ReWriter (Black) - OEM £17.99
Total : £482.90
Change ran to XMS3. Cheaper, and everyone uses it so it works.
Change case to a 430 Elite :) Failing that, the midgard at £30 is a far better case, even if it's white.
And I would pick a 560ti over a 6950 1GB.
EDIT : I dont like OCZ stuff, but the ModXStream specs look OK.
