- 11 Sep 2008
Ok freind has 450 to spend on a tower (No keyboard, mouse, OS required, so just components) He wants to max WoW and SC2.
Thanks as always guys
Agree, for those games, the athlon x4 is the way to go, personally I'd try a cheaper psu like corsair cx430, should still be enough, and get better mobo
Palit GeForce GTX 460 768MB GDDR5 PCI-Express Graphics Card with HAWX2 PC-Game £119.99 (£102.12)
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard £69.99 (£59.57)
AMD Athlon II X4 Quad Core 630 2.80GHz (Socket AM3) - Retail £69.31 (£58.99)
Patriot Viper 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (PVS34G1600LLK) £61.09 (£51.99)
Corsair CX 430W ATX Power Supply £37.98 (£32.32)
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ) £33.98 (£28.92)
Coolermaster Elite 335 Case - Black £32.99 (£28.08)
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £13.99 (£11.91)
Sub Total : £373.90
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 17.50% VAT : £67.49
Total : £453.14
and get better mobo
Genuine question . . . why do you guys say this is a better mobo for the O.P?imo the better motherboard is more useful
While I agree that 430watts should be enough power it does limit future options a little and the Corsair unit isn't modular . . . it also only has a single PCI-E 8 Pin Connector so won't power the GTX 460 unless an adapter is used?430w is enough to power that system anyway.
That is a really old and basic design, non "thermally improved" with the PSU sitting at the top and no roof blow holes? . . . there are plenty of better choices than this at around the same price point . . . . Case and PSU tend to last in a build the longest . . . even with £450 then is no need to scrimp so much that both these important parts get cut right down!Coolermaster Elite 335 Case - Black £32.99 (£28.08)
Genuine question . . . why do you guys say this is a better mobo for the O.P? Than this £21 cheaper model?
imho get a 500-600w psu (that ocz sx2 600), the 430w may do the job but limits any kind of future upgrades etc.
and the Corsair unit isn't modular . . . it also only has a PCI-E 8 Pin Connector so won't power the GTX 460 unless an adapter is used?
Pity this has run out of stock . . .
