spec me £475+case
5 Jun 2013
hello
i want a new rig, everything included , except mouse and keyboard os, and tv card, , desk, printer, webcam
monitor included size doesn't matter, need to be bigger than 20 inches
aso i need a wireless adapter, usb or PCI
rig will be used for gaming like CoD Black Ops II, BF3, BF4, Far Cry, and GTA5, and many other games
the case is a separate budget of £35
i saw 2 and and i dont know which one to choose
1st one:
specifications:
Form Factor: Midi Tower
Motherboard Support: ATX, Micro ATX, Mini ITX
PSU Support: Standard ATX
Dimensions: 193mm x 455mm x 475mm (W x H x D)
Packaging Dimensions: 500mm x 520mm x 235mm (W x H x D)
Body Material: 0.5mm SPCC
Front Bezel Material: Plastic and Mesh
Side Panel: Vented
Front Bezel Colour: Black
Body Colour: Black/Red
Expansion Slots: 7 x Full Size
System Cabinet Features: 2pcs of ODD screwless,2pcs of SSD screwless and 2pcs of HDD screwless.
Red motherboard plate.
Hole underneath the CPU Cooler to allow easy access when installing or swapping the CPU Fan.
Internal Cable Management system
Water Cooling ready: 2 Pipe Holes (No Gromits)
PSU Included: No
Net Weight (KGs): 4.5 KGs
or this one:
specs:
Cooling Fans:
# 120mm Red LED Front Cooling Fan
# 80mm Red LED Side Cooling Fan
External Ports:
# 2 x USB 2.0
# Audio ports (Headphones and Mic) (On front of case, on side of the fascia)
Dimensions (mm): 451mm x 186mm x 424mm (D x W x H)
thanks in andvance
MHD
edit:
what about this:
YOUR BASKET
1 x Intel Core i3-3220 3.30GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £92.99
1 x BenQ GL2055 20" Widescreen LED Monitor - Black £89.99
1 x MSI GeForce GTX 650 Black Knight OC 1024MB GDDR5 PCI-Express Graphics Card £79.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £53.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PV38G160C9K) £49.99
1 x Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard £45.95
1 x Xigmatek No Rules Power 500w Power Supply £44.99
1 x TP-Link 300Mbps Wireless-N USB Adapter (TL-WN821N) £12.98
1 x Xigmatek 75 in 1 3.5" Internal Card Reader - (CPH-7SPNU-U01) £4.99
Total : £489.36 (includes shipping : £11.25).
The 650 isn't a very good performer. Get the 7790 for £99.
The i3 will struggle with the latest games having only 2 cores. You can get a 2500K second hand for about £100.
i dint want get anything for second hand, as i have a bad expericence getting an pentium in second hand
would it better got for a 6300, or a 6350?
Ogawd, that 2nd case is ugly :p
The 1st one remidns me of a HAF series.
Get a Xigmatek Asgard Pro for that money!
As above, get a HD7790 can be had for £89 too.
Better/modular PSU
http://www.overclockers.co.uk/showproduct.php?prodid=CA-115-CS&groupid=701&catid=123&subcat=2462
i think i would go for the first one, and is the same price, but better looking and cooling, as it gor 4 fans included on the price
the psu can you spec me a 500w one? as it i will add 3 dvd drive on the feature
MHD
well cases are personal preference after all.
And no I wont spec you a 500w PSU :p
430w is more than plenty enough for that system and wont have a problem with 3 more dvd drive.
I'd go for a 6300 over an i3 any day unless you want it for older games only, the latest and future games are better with 4 or more cores, e.g. Crysis 3 really suffers on dual core. It'd be better to go for a 970 board rather than a 700 series one.
7790 is the best card under £100, so unless a B-grade 7850 comes along that's fine.
Cant comment on the Cpu/platform side of things but I would always pick intel for my builds :p
22" monitor
http://www.overclockers.co.uk/showproduct.php?prodid=MO-085-BQ&groupid=17&catid=949
Thanks for the better monitor
I think i will go amd route the first time, i got an pentium 4 at 3.6 ghz single core, would i nottice a lot of diferrence going for an 6 core?
Ionly choose the 700 series because of the price, i really dont wanta pass £500 with the case
Mhd
This game is seriously hard on the GPU, but it's an example of how limiting an i3 can be compared to an i5, where all the recent 4+ cores do more or less exactly the same:
http://cdn.overclock.net/e/e7/e729d880_crysis3_cpu_jungle_1920.png
This example isn't supposed to be representative of all games, just a very recent one which is optimised for multi-core.
The shortfall here of the 6300 could be made up mostly with an overclock as shown in the benchmark.
Although 430w is fine for the i3, I would go for ~500w for the 6300 because of the extra cores. 430w would be ok though.
Do you have a cooler already? Without one overclocking will be really limited.
i am not thinking of overclocking right now to save a few ££££, the budget is very limited, as my mum wont give more, that's ok, because if you think its a lot of money for a 13 year boy to spend
MHD
