Spec me a 1070 build please
All bases checked apart from the cooler. I wouldn't want to skimp on anything else just to squeeze in the H100i.
The areas you could skimp on would be power supply and SSD storage but power supplies are a key component which can sting you if you go for cheaper or less well made ones, and 256gb SSD is the minimum I would advise. You can go less but speaking from experience its annoying! You could also go for a mechanical drive instead of the SSD but its makes such a big difference to everyday usability I wouldn't be without one. RAM also you could drop to 8gb which would get you under budget at least but some games like GTA V will happily use more than 8gb so be warned.
My basket at Overclockers UK:
Total: £1,012.84
(includes shipping: £0.00)
Ok, so here's what I've refined it to.
I have a case (CM Trooper), 480GB SSD and a Corsair TX 750W ATX2.2 SLI Compliant PSU which I will place in this build.
Anything I've missed or glaring mistakes?
Thanks,
Total: £1,329.95
Thanks,
Total: £1,329.95
Don't forget the cpu cooler.
