Spec me a 120.3 cpu loop!
14 Jan 2010
£150-£180 budget but if you can spec something cheaper that will do the job just aswell...
Needs to have a Res in the loop and i plan to put this in an ATCS 840.
Go go go go go!
Your basket
Product Name Qty Price Line Total
Black Ice SR-1 360 Radiator £69.99
(£59.57) £69.99
(£59.57)
XSPC Dual 750 Bay Reservoir & Pump - Clear £52.99
(£45.10) £52.99
(£45.10)
Heatkiller CPU Waterblock Revision 3 (Socket LGA775) £49.98
(£42.54) £49.98
(£42.54)
Sub Total : £147.21
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 17.50% VAT : £27.51
Total : £184.72
True but the one i linked to is on offer atm normally £49.99, so definitely worth a thought. Its not that much thiner then the PA's so at that price point its a good buy i think.
The PA 120.3 is still on sale, just not on Overclockers lol.
Go for the EK rad that bifday2k linked to and change the block to the EK Supreme HF Universal. It's better than the Heatkiller and fit's all current sockets.
MR J makes a good suggestion
however........... two minor alterations
I WOULD save your money right now as THERMOCHILL are about to realease the TA series of radiators offering increased performance.
THis means tha the PA series may go down in price, ill have a word with paul and robn for you if you wish?
Next the heatkiller 3.0 is a good choice however for a much less price say £42.99 you can get an XSPC RASA block and it performs a clear 2c cooler than a heatkiller 3.0
I have a review on my site if you wish to enquire. I wont post a link yet as i dont wish to spam.
gilgamesh
gilgamesh
Intriuging! So approximately when will the TA series be released ?
xspc bayres/pump combo
ek triple [its £30 :eek:]
a good 1366 waterblock [spend about £40-£60]
buy some 7/16 tubing and 6 half inch barbs
get some deionised water or buy some coolant
should come in under £100
done
you can save additional money by using ek FATBOY g1/4 to half inch id barbs in conjunction with 7/16 id tubing
Reason is that you would have to dip the tubing end into hotwater in order to expand it, then slip it onto the barb. It will then cool down and fit so snugly that you need a stanley knife to cut it off-hence eliminating the need for hose clips or expensive compression barbs
7\16 id tubing offers very close to the same flow path as 1/2" id but with the added advatnage of taking less physical room in your case AND its cheaper
note pump\bay res is a good combo for a budget but sumerged pumps dump 100% of their operating temps directly into the fluid non, submerged is around 60%
