spec me a 120mm fan with high output
8 Nov 2002
Parson Drove near Wisbech
As title I would like a very high air volume (cfm) would like it to have blue leds as its for the front of a coolermaster elite 335, I know you can buy crappy fans but thats deff not what I would like, if no leds maybe I could put some in the front to lighten it up a little. Any help appreciated, cheers guys.
Deltas + LED = Win :p
they do shift an insane amount of air, although they make more noise than a small aircraft. I used to have one of the akasa led fans on the front of my coolermaster 335 and although they are quite loud, they still move a fair bit of air and managed to keep everything nice and cool.
I've since replaced them with scythe kaze's as the computer as they're a lot quieter, but if you want leds then the akasas are great.
deltas + ear defenders + LEDs
or
noctuas + LEDs
it depends on whether you want 10% more air shifted, or 50% less noise. I'd go with the noctuas any day.
tbh ive got about 7 or 8 sharkoon silent eagle 2000's in my case atm and i cant knock em. they are the same sort of price as the noctuas and have a golf ball texture on the blades, also the black/white colour scheme i cant fault...
Delta's do move the air but are a bit load for me, I may go for the Noctuas and stick 4 small led's in each corner low wattage not the realy bright one's just want a little colour at the front, Thanks guys for all the help I really appreciate it very much.;):D
