Spec me a 1440p Monitor
15 Jan 2010
Scotland
As per the title, just looking for an upgrade from a 23" 108p TN monitor. I've been at 120Hz so I'd like the higher refresh rate in the new monitor, and would also like to try out G-Sync,
is there anything that is 'cheap' with these specs? Or are we looking above £500 realistically?
Been looking into the Dell and it seems promising, I know IPS displays are more expensive but I've never had one so don't think I'll be disappointed with a TN panel?
If you're going to spend £500+ on a monitor, look into the ultra-wide screens, at least you will get a wow factor and I believe 21:9 is going to slowly kill off 16:9 as did 16:9 to 5:4 and has even killed off 16:10, you can only find 16:10 in a few places under the professional range now.
Acer Predator XB270HA 27" 144Hz G-Sync Monitor
1920 x 1080 Full HD
G-Sync
1ms Response Time
DisplayPort + USB 3.0 Hub
144Hz Refresh Rate
Saw for £379 on amazon and e buyer
has everything you need but 1080p on a 27 inch. it shouldnt be an issue for games.
