spec me a £150 build max
1 Aug 2012
Stoke-On-Trent
Hey guys,My uncle needs to upgrade really bad and i can take his old parts out like HDD Optical drive and PSU also the case.
He's using a pentium 3 atm so all i would need is a new CPU,Heatsink,Mobo and Ram.
It would be used for browsing and playing CaC. Many Thanks in advance.
If the PSU is the same age as the pentium then you'll almost certainly need either a new PSU or a 20pin - 24pin adapter cable as the old ones only had a 20 pin ATX connector. Motherboards now require 24pin
YOUR BASKET
1 x Intel Celeron G550 2.60GHz Socket LGA 1155 Processor - Retail £35.99
1 x MSI HD 6450 SILENT 1024MB GDDR3 PCI-Express Graphics Card £31.99
1 x TeamGroup Elite 4GB (2x2GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED34GM1600HC11DC01) £29.99
1 x Foxconn H67M Intel H67 (Socket 1155) DDR3 Micro ATX Motherboard £29.99
Total : £138.46 (includes shipping : £8.75).
