Spec me a £1500 amd system
Permabanned
22 Sep 2003
ok guys no need for a screen or hard drives the rest i need what can u do love to be able to get 3gig and 2 gig of ram
Shopping Cart (Prices in British Pounds) REFERENCE DESCRIPTION QUANTITY PRICE COST REMOVE
CP-148-AM AMD Opteron UP 170 Dual Core San Diego 2.0GHz 2MB Cache (Socket 939) - Retail (CP-148-AM)
£299.95 £299.95
GX-047-HT HIS Excalibur ATI Radeon X1900 XT-X 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-047-HT)
£359.95 £359.95
MY-008-GS G.Skill 2GB DDR HZ PC4000 (2x1GB) CAS3 Dual Channel Kit (F1-4000USU2-2GBHZ) (MY-008-GS)
£129.95 £259.90
MB-017-DF DFI LanParty UT RDX200CF-DR Crossfire (Socket 939) Motherboard (MB-017-DF)
£124.95 £124.95
BU-000-WD Western Digital Raptor 74GB 10,000RPM SATA 8MB Cache RAID Bundle (BU-000-WD)
HD-015-WD Western Digital Raptor 74GB WD740GD 10,000RPM SATA 8MB Cache - OEM (HD-015-WD) 2
£197.90 £197.90
CA-027-AN Antec SLK3000B Midi Tower Case - No PSU (CA-027-AN)
£27.50 £27.50
CA-025-EN Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU (CA-025-EN)
£63.95 £63.95
HS-010-ZA Zalman CNPS7700-CU Ultra-Quiet CPU Cooler - Retail (HS-010-ZA)
£22.95 £22.95
CD-033-LG LG GSA-4167BAL 16x16 DVD±RW Dual Layer ReWriter (Black) - OEM (CD-033-LG)
£25.00 £25.00
Subtotal £1,382.05
VAT £241.86
Total £1,623.91
Bit over budget but that is one of the most powerful pcs possible.
Just noticed you don't need harddrives. If you remove the 2x Raptor 74gig combo it comes to £1400 inc vat. Under budget. Could treat yourself to a razer copperhead and logitech gaming keyboard or something.
The processor should reach 2.8 - 3ghz stable, dual core, 4 gig ram, fastest graphics card on market etc.
4x1gb of ram will be slower than 2x1gb and not needed. I would just get 2gb and get a case worthy of a £1500 computer (V1000 for example). And the big typhoon for the cooler.
It's true that 4gb ram will run at 2t rather than 1t which makes it a bit slower, but he requested more than 2gig ram so if he needs the extra ram 4gig is fine. I agree he could get a more expensive case however he didn't give me much to go on of a description of his system in mind, the Antec is a perfectly sound case although not the best looking, he could upgrade to a more expensive silverstone or similar case if he's into flash but it wouldn't affect performance.
DragonWoLf said:
how about an Fx-60? stock at 2.6, OC it to even more higher, hell for £1500 i woulds
Yeah that seems like a good idea... oh wait no it doesnt
If you spend £750 on a cpu it doesnt leave much for the rest of the computer, and the 170 will clock almost as high with the actual amount overclocked being higher.
