I've got a friend who asked me to build her a PC for Articad design. https://www.articad.com/products/articad-pro/
It's CPU/core intensive so more cores the better, hence me thinking a 1st gen threadripper would be a good solution for her. (Minimum 8 core 16 thread needed so even 2700 AM4)
16 gig of RAM minimum - compatible with TR, probably 32 gig would be better
Motherboard
Power supply
Case (that fits TR4 setup)
NVME drive for windows and articad software
Storage drive for renders
CPU cooler - hassle free as she's not that teach savy with hardware
Basic GPU that can power 2 monitors. GPU will NOT be needed for gaming, just to power 2 monitors. Outputs needed are HDMI for one monitor and she's not sure wohat the other monitr is so have to consider it's either also HDMI or DVI. Need a GPU with multi output option then to cover the second monitor, whatever socket it may use to connect to the card
Is a 1st gen TR4 with the above doable for £1000?
Motherboard
Power supply
