spec me a 200 pounds upgrade
233
233
21 Nov 2004
Wishaw
current setup is as follows
e2160 running at 2.2ghz(maxium i can get out the mobo)
gigabyte 945gcmx-2
2 gig generic pc5300 ram
1900xtx
500w powersupply(actually quite decent)
dell 2007FP 1600x1200
was thinking along the lines of a good clocking mobo and decent cooler to get another ghz of speed out of the poor underused 2160
something like as asus p5k and an freezer pro and then another 2 gig or pc5300 but i'm sure i'll get some better suggestions from here :)
main uses are um gaming and um gaming,(mainly fm2008 and a bit of cod 4 which actually seems to run rather happily as is
reason i ask is that the p5k is a over the top in terms of features
i need
100mb/sec network port
1x eide for my dvd drive
some sata ports
on board sound
oh and the option of raid would be nice but not required
How about a gigabyte GA-P35-DS3L, Freezer 7 Pro and upping the memory to 2Gig of pc2-6400?
Simply adding another 2Gig of pc2-5300 is pointless unless you've got 64-bit OS.
how does the ga-p35-ds3l clock?
assuming it will max out a 2160 to over 3ghz
how does this look?
Product Name Qty Price Line Total
Gigabyte GA-P35-DS3L Intel P35 (Socket 775) PCI-Express DDR2 Motherboard £55.99
(£65.79) £55.99
(£65.79)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £28.99
(£34.06) £28.99
(£34.06)
Arctic Silver 5 Thermal Compound (3.5g) £5.99
(£7.04) £5.99
(£7.04)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775) £14.99
(£17.61) £14.99
(£17.61)
Total : £134.20
GA-P35-DS3R
Mate has taken the E2180 to 3Ghz on stock cooling with loads of 60 degrees on the L, which is almost the same. With the Freezer 7 and some PC2-6400 RAM you will easily get 3Ghz+
My Vote:
Gigabyte GA-P35-DS3R (Socket 775) PCI-Express DDR2 Motherboard (76.36)
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) (£34.06)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775) (£17.61)
Shipping : £8.25
Total : £137.73
But do you really need RAID?
nah no new gfx waiting on the new 9 series :)
so need mobo ram and cooler for a decent oc on a 2180?
guys?
what u reckon
final buy list..... any changes to make
(£65.79) £55.99
(£65.79)
G.Skill 2GB DDR2 PK PC2-6400C4 (2x1GB) CAS4 Dual Channel Kit (F2-6400 £31.99
(£37.59) £31.99
(£37.59)
(£7.04) £5.99
(£7.04)
(£17.61) £14.99
(£17.61)
that ram or 2 gig of ocuk pc8500?????
and mobo?
