- 14 May 2012
I know this is a little specific however there are some reason to what I want:
I have just bought a Sapphire 7970 HD Vapor-X 6gb, and I want to move to a 3 monitor setup.
I currently have 2 monitors on a 560 Ti.
On is a Dell ST2220T (1920x1080 touchscreen), the other I have no idea... other than the fact that it's a 1600x1050 monitor.
I'm only looking to purchase 2 monitors (replacing the 1600x1050).
As far as I understand I need 2 monitors, at least one of which has a displayport input to enable Eyefinity, or I need an active displayport to DVI converter.
So I'm looking for either a 22" monitor with a display port, or just 2 good 22" monitors and an active converter (assuming the one bundled with the grfx card isn't an active one as it doesn't have a USB connector).
I would also rather that they support at least a 1920x1080 resolution.
There are several reasons for not dropping my touchscreen:
a) My daughter likes it
b) I have windows 8 (don't judge me)
c) My wife will (probably) notice if I change it
EDIT:
Will I be disappointed with This?
Or do I just throw caution to the wind and start buying these?
EDIT:
