Spec me a 22" widescreen monitor
23 Dec 2002
Shiny Shanghai
Nuff said :)
But it also needs the right connections to be a HDTV for if I decide to get a 360 or something in the future.
Looking for about £150 ish !!
Ta !!
Hi there
The best value for money 22" is the Samsung 223BW without a doubt, available on OcUK's This Week Only. It has analogue and DVI connections, plus far better colours and crisper picture over the slightly cheaper options from the likes of Cibox, Acer etc.
Nuff said :)
Ta !!
As long as it has VGA you can use your 360, VGA is widely regarded as superior to Component for the 360 anyway. (Used to use Component myself, VGA is far superior)
Cool !!
This might sound stupid, but do all monitors have the same connection to the gfx card ?
You know, kinda like this with the circles being pins ?
Gibbo, could you confirm (or not) if that monitor you suggested does not have adjustable height and tilt as I have been told ?
Cheers
Cool !!
lol yeah they do, but it would have been easier to find an image on google or summit than wastin all that time on paint, must have taken u ages...
