Spec me a 24" monitor!
8 Oct 2009
I am building a new core i7 rig and will buy the ATI 5870 gfx.
I need a 24" monitor for gaming/work.
Resolution wise - 1920x1080 / 1920x1200
What's the difference between them since the monitor is 24"?
Also I would like to use the potential of the gfx...
so can you recommend a new monitor? And state why it is a good monitor pls as I don't understand much about them.
Also which brand would be best?
Thanks
You want something with a good pannel and shows you the blacks to be black and little light bleed. You also want something with a low responce time for gaming and good colour reproduction. These are the things you will be looking for.
