30 May 2010 at 17:10 #1 lauy lauy Associate Joined 16 Apr 2008 Posts 387 Spec me 24" one Budget: No more than £170 Input not so important just the best I can get for the money Thanks.
30 May 2010 at 17:22 #2 cmndr_andi cmndr_andi Soldato Joined 23 Apr 2009 Posts 11,973 Location Cheshire This BenQ is pretty much the best monitor you can get for this budget. What will you be using it for mainly?
30 May 2010 at 18:06 #3 lauy lauy Associate OP Joined 16 Apr 2008 Posts 387 Will be used for gaming and video editting. Looks a good bet I think, read a few reviews about that on here
31 May 2010 at 13:02 #4 lauy lauy Associate OP Joined 16 Apr 2008 Posts 387 Any suggest any others because that seems to be pre-order but I need the monitor sometime this week? Thanks.
31 May 2010 at 14:57 #5 Klo Klo Soldato Joined 20 Nov 2005 Posts 4,112 Location South East lauy said: Any suggest any others because that seems to be pre-order but I need the monitor sometime this week? Thanks. Click to expand... Looked at alternative sites?
31 May 2010 at 16:13 #6 ViRuS2k ViRuS2k Soldato Joined 26 Jan 2004 Posts 6,293 Location Scotland lauy said: Any suggest any others because that seems to be pre-order but I need the monitor sometime this week? Thanks. Click to expand... i see 1 in stock
1 Jun 2010 at 09:30 #7 lauy lauy Associate OP Joined 16 Apr 2008 Posts 387 Alright will do cheers. Says 'Pre-order' for me
4 Jun 2010 at 13:23 #8 Dannowoo Dannowoo Associate Joined 4 Aug 2009 Posts 21 Location Laahhndahn. It's definitely pre-order only, I ordered mine on the weekend and got webnote confirmation that it's on pre-order this morning.
