Spec me a 3GS hard/complete case!
18 Oct 2002
Hereford
As the title really guys! Spec/recommend me a hard case!
Picked up a cheap (!) 3GS to run the rest of my 24 month contract after my nokia N900 started playing up...
I work outdoors in the dust & dirt so would like a good solid complete case, with screen cover! Don't mind if it means having to flip/slide the phone before using... Have already had probs with dirt/sawdust getting into the port! :(
Am currently using a gel like wraparound one and it's nowhere near enough as has no screen protection!
I Like the Incase Sliders. Full protection and the bottom half separates for when you want to use the phone in a dock. I found that it can cause some scratches on the back if you separate the bottom part a lot and manage to get some dirt in there :(
Thanks NightShadow, i'm not too worried about taking it out of the case for docking/charging/using!
Ordered one of these -http://cgi.ebay.co.uk/Hard-Carry-Case-Pouch-Apple-iPhone-3G-3GS-Black-/270741152110#ht_1206wt_905
Will let you know what it's like when it arrives!
