Spec me a £400 PC
11 Oct 2005
Derbyshire
Hi, not really up on what is out there at the moment. But want a new PC with the following spec:
i3 / i5 CPU
8GB Ram
Hard Drive: not bothered what size
OS: Win 7 64
Mouse / Keyboard
20" Monitor (HD would be nice)
Basic case
Will be used for basic web design, little bit of video editing and general office duties.
Thank you.
Hi Magic X,
I'm not up to date on these things either, but I asked for a very similar computer yesterday, might be worth you having a look at this thread.
You'd need to add a copy of Windows 7 to the list which would take you slightly over your budget, but you could remove the SSD to make up the difference. Hope this helps.
http://forums.overclockers.co.uk/showthread.php?t=18430808
EDIT: Just noticed you need a monitor as well, that would take you well over your budget :( Might be best waiting for someone who knows what they're talking about
i3 / i5 CPU
8GB Ram
OS: Win 7 64
Mouse / Keyboard
Basic case
Thank you.
Unfortunately I highly doubt you will get much for that price including a monitor.
YOUR BASKET
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £89.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
1 x Toshiba MK6475GSX 2.5" 640GB 5400RPM SATA-II 8MB Cache - OEM £57.98
1 x ASRock H61M-GS Intel H61 (Socket 1155) DDR3 Micro Motherboard £38.99
1 x Xigmatek Tauro 400W '80 Plus Bronze' Power Supply £35.99
2 x Adata XPG Gaming v1.0 4GB (1x4GB) DDR3 PC3-12800C9 1600MHz Single Channel Module (AX3U1600GC4G9-1G) £23.99 (47.98)
1 x OcUK Flamingo FM-12A Midi Tower Case - Black/Red £21.98
1 x Samsung SH-118AB/BEBE SATA 16x DVD-ROM (Black) - OEM £14.99
Total : £405.38 (includes shipping : £11.25).
This is with the cheapest parts OCuk have to offer and yet i couldnt get you a Monitor or keyboard..
You will have to raise your budget slightly by approx £100
Or you could go with this....
YOUR BASKET
1 x "Primo 6100i" Intel Core i3 2100 3.10GHz DDR3 Dual Core System *** FREE UPGRADE TO INTEL CORE I3 2120 3.30GHZ CPU *** £251.98
1 x No Hard Drive Upgrade £0
1 x TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38192M1600HC11DC) £29.99
1 x ATI Radeon HD 5450 SILENT 512MB GDDR3 PCI-Express Graphics Card £22.99
1 x System 12 Months Standard Warranty £0
1 x Opt Out of FREE AV Software £1.26
Total : £408.80 (includes shipping : £15.50).
But again you will need a monitor, keyboard and mouse...
A pentium G620 would be ok for basic web design.
If T345 dropped it to a pentium, you would be within budget and could get a better case. Rather than a case that will bend under any weight.
