spec me a 43" TV
15 Jul 2005
UK
hi guys
can anyone spec me a 43" TV to go in my kitchen please... TV will be on a corner unit, will be mainly used for Xbox Series X (when i get one), freeview and possibly a Nintendo Switch.
I was originally looking at a Samsung QE43Q60T but i read a comment on this forum that it suffers from stuttering issues, not sure if thats true.
budget is 600-650 quid
thank you in advance.
You can get a Sony Bravia KD43XH8505BU for £679 from Richer Sounds right now if you're willing to spill over the budget by a few tens
Usually a £750 TV and if the 49 inch version of the same line is anything to go by it's probably one of the best you can get in your price range
The Sony Bravia KD43XH8505BU is 100hz as well which I think is the only TV out there at that size higher than 60hz? No HDMI 2.1 though, the sub 49" selection is really dreary.
