Spec me a 4K HDR TV for PS4 PRO
5 Feb 2012
Am after a 4K TV with good HDR support not this terrible dim stuff. Mostly gonna use my PS4 pro on it with Netflix etc.
I've heard a lot of these TVs have banding issues and motion blur so I'd like to avoid the worse ones.
Nothing bank breaking too please, my credit card does not go far enough for OLED that's for sure xD
Thanks!
For what you are asking it to do, I'd just save some money and go with the 40" Samsung UE40MU6400. Can be had for around £400 now. Otherwise for £600 if you want it to be bigger grab the 55" UE55MU6400.
Don't find Samsung's VA panels impressive in terms of brightness. More after IPS if possible o; Sony seems to have a few
If you are going 40" and trying to save some money, you won't really get better than that panel at the moment. If you however want to go bigger, then yes lots of other options.
Hi
If you can find one the LG 43UJ750V is worth and look and is within your budget.
http://www.lg.com/uk/tvs/lg-43UJ750V
I have one and can highly recommend it for gaming it has a super low input lag of 15ms when in game mode and its IPS too.
II use it as monitor also and i cant see any banding issues and motion is more than good enough for gaming.. it will even run @ 1080p 120hz.
LG I believe use RGBW rather than RGB. Ended up going Panasonic due to there very low input lag and price tag. Thanks for the tips though guys
