Spec me a £50 watercooling case (no modding)
22 May 2010
Minibotpc
This is for my brother who wants to go full water cooling but im struggling to find a case within the price range that will fit a 240 rad up top or at the front without some serious modding done to it.
Can anyone help?
Thanks
CM690 II is about the only case I can think of that meets your requirements, might be a shade over budget but it'l take a pair of 240 rads without modding.
I do like this case, would it be a 240 up top and a 240 down bottom? Can't tell if the HDD caddies are removable or not.
240 in the bottom depends on your PSU
if your PSU is a long one then you won't squeeze a 240 in. I am in the process of specing out a water cooling solution for my cm690 adv and the PSU i have (XFX 750W) is just long enough to twist my melons.
SO I am thinking of a 240 slim up top and a 140 down below
