How about this ...
Asus A8R-MVP Crossfire (Socket 939) PCI-Express Motherboard (MB-129-AS) £82.19
AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - OEM (CP-150-AM)
£146.82
OcUK Value 2GB (2x1GB) PC3200 184pin DDR Memory Dual Channel Kit (MY-006-OK)
£105.69
Samsung SH-W162C 16x16 DVD±RW Dual Layer ReWriter (Black) (CD-068-SA) £26.97
Antec Performance TX640B-EC Black MiniTower Case - 400 Watt SmartPower PSU (CA-034-AN) £72.26
HIS Excalibur ATI Radeon X1800 XL 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-042-HT) £223.19
Total:£657.12 (including VAT)
This option is if you transplant the 120 GB HDD from old system to this.
Really fast CPU & graphics card (a card known to overclock really well). Combined you wont have problems for quite a while. Good mobo with all connectoins your likely to need. 2GB ram will do you really well in games & other apps. Good case with decent PSU - enough for what you have now & to still add extras. Great burner added too.
If you cant keep existing HDD then this optoin would suit..
£146.82
£105.69
Samsung SpinPoint P SP2004C 200GB SATA-II 8MB Cache - OEM (HD-017-SA)
£68.09
PowerColor ATI Radeon X850 XT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-037-PC) £146.82
Total:£648.84 (including VAT)
Same as above but has a great 200GB HDD & the graphics card is still great & enough to run all games with.
** Either system will be way better than your current rig **
Enjoy
