Spec me a basic general use router
11 Oct 2011
UK
Hi,
I am in need of a new router. Nothing special just a basic router. Majority of the time it is used wired but very rarely it might be used wireless so please spec a wireless one and one without wireless as I'm guessing it will be cheaper? So might go for wired only if it is a lot cheaper.
I know I said basic but I do need to be able to set up port forwarding on it to remotely access a device but I think even basic routers would let you do that?
Really don't want to spend any more money than we need to, which router would you recommend?
Hope you can help
ADSL or Cable?
ADSL... It works on a standard telephone line broadband connection
Current router that has stopped working is a Linksys wag160n but it doesn't need to be replaced with anything g of that high spec. Just a good, reliable, sensibly priced one that will do the job
Thanks!
