Spec me a basic media player graphics card!
11 Nov 2005
Ok I'm building a media pc for use with my tv, im canalising some old computers but need a graphics card, only very basic is needed as no games etc! I'm very out of touch with building pc's nowadays! Well see my sig!!
If you mean a standard PCI slot, then no.
However, if you are looking to install a pci e 2.0 card into a pci e 1.0 slot, then the answer is yes; with certain limitations. Basically, the pci e 1.0 will only be able to carry half the bus bandwidth. I honestly can't see how this will dramatically affect the performance of a low end card though.
