Spec me a battery - and where to get it cheap!
22 Dec 2002
Minehead
Hey,
Battery in my Bora TDI is on its last legs I think (getting slower turning over and I figured I'd stick a multimeter across it tonight and after being left around 20 hours its reading 11.9volts).
I know the alternator works ok, 13.8 when running and all electric equipment on.
Some sites suggest an 096 battery, whilst others say something larger. I had a bosch silver previously on my rover which lasted over five years of happy service.
Can anyone suggest me a decent battery at a decent price please? Not looking forward to trying to start it tomorrow as I have a feeling that with a registered 11.9v it may tell me to go walk!
Thanks
Before spending loads on a new battery. Try topping up the fluid first, and put it on a conditioner over night.
Its sealed, or I'd check the levels :(
I found ebay cheapest too, problem is - even eurocarparts list two batteries for my car. One says 096, one is a 110.
I'm going to attack it with a tape measure in a minute and see if I can make any sense out of it that way!
