Spec me a beast for £2000 please
5 Feb 2013
Clockers it has been a while however I am back and looking at treating myself to another machine. Can you spec me an i7 machine which I will be using for everything media from 3d blue ray, gaming, video editing etc. I am thinking a Titan as minimum for GPU as I will be looking at 3 x 1080 monitors (monitors not to be included in this spec please I will be buying them seperately), however I am open to suggestions.....this machine has to do everything I ask of it....i.e. it has to play Crysis 3 at very high and be able to do video editing. I am saying beforehand that I love Corsair products, but again I am not saying I wont look at others.....I would like the Corsair 540 air case though and proper liquid cooling like say XSPC maybe? Thanking you all in advance.
I wouldn't go for the Titan. If you don't want to wait for the new AMD GPUs, for less money you could get 7970 trifire.
XSPC RayStorm D5 RX360 WaterCooling Kit
EK Water Blocks EK-FC7970 - Nickel Plexi CSQ x2
XSPC RX360 120mm Radiator
Thats your water cooling cooling taken care of. 2 rads should be enough for the 3 items. You will need to add fittings ie 45/90 etc
as for pc components 2 of the MSI 7970 boost editions
4770K + Gigabyte Z87 OC + 16GB of ram (2 x 8gb) + Samsung EVO SSD drive.
I think the 2 rads should fit into the 540 case
