Spec me a bedroom pc
22 Jun 2005
Nottinghamshire
Product Name Qty Price Line Total
OcUK Digimate LTV-3212H 32" HD Ready LCD TV £239.99
(£281.99) £239.99
(£281.99)
Asus M2A-VM HDMI Micro ATX (Socket AM2) PCI-Express DDR2 Motherboard £39.99
(£46.99) £39.99
(£46.99)
Antec NSK 3480 Micro ATX Case - 380W Earth Watts PSU £49.99
(£58.74) £49.99
(£58.74)
AMD Athlon 64 X2 Dual Core 4600+ 2.40GHz (Socket AM2) - Retail £36.99
(£43.46) £36.99
(£43.46)
LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive - OEM £66.99
(£78.71) £66.99
(£78.71)
Samsung SpinPoint F1 500GB SATA-II 16MB Cache - OEM (HD502IJ) £39.99
(£46.99) £39.99
(£46.99) Sub Total : £473.94 Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £24.74 VAT is being charged at 17.5% VAT : £87.27 Total : £585.95
So far I have the above, really only require memory, it will be used in the bedroom for watching DVDs and hopefully hd/bluy ray disks and linked via hdmi to the screen.
I am not sure which memory is suitable for this application, in fact will the spec be ok, the budget is 600 excluding VAT.
if your hooking it up to a HD TV, and you got a HD,blue-ray drive. have you thought about a 780G chipset, does full onboard decoding of HD media.
yep thats the one, i like this one more
http://www.overclockers.co.uk/showp...ATX (Socket AM2) PCI-Express DDR2 Motherboard
£58.74 inc VAT, but you could pick one up on the MM for £40 ;)
EIDT: the onboard graphics is actually very good, and can handle decoding HD media, offloading the work form your CPU, you can use a 2GHz processor, which means less heat, therefore less noise
EIDT2: goggle "780G review" read the first few links
yeh that's what he means. What you going to use the pc for?
To play hig def films (blue-ray, HD-DVD) it has to be decoded the 780g chipset will do it without using the main cpu.
:p
