This is a complicated question so i will explain it the best way i can
I have recently upgraded to sli 480 gtx's which i am very happy with
They are both technically gigabyte soc 480 gtx's which should take up 2 expansion slots but one of the cards has a shaman cooler on which is massive and takes up 4 or so
My current case is a cooler master cm-680 light which doesn't give me enough room to fit both cards. I can fit the soc card to the top pic-e slot and the shaman card to the next pci-e slot but doesn't give me enough room to fit the psu as well
I need a case with awesome cooling because the shaman card runs at around 60c which is fine but the soc card runs at 80-85 c at load and i am melting in my room !
My budget is 140 pounds but i can stretch to more if needed but i would rather keep to said budget
I can supply pictures of the size of the cards and the problem i have if needed.
