Spec me a build £2000
3 Nov 2011
So the PC in my sig has died a horrible death due to a water leak. I am looking for a build around the £2000 mark I am an Nvidia fanboy at heart but could be swayed by a 7990
No Mouse/Keyboard/Monitor required
Not had any experience with SB E my old SB chip was a good clocker :( Not kept in touch much with the current gen but I have heard that haswell runs hotter than IB/SB?
Is SB-E really worth it compared to Haswell ? I will mainly use my PC for Gaming and nothing much else that would tax it.
Its not worth it then.
The water had nothing to do with the PC I have no problem with the water coolers. The water was actually a leak from my neighbour upstairs water fell directly into the top fan vents of the phantom and into the PSU
I wasn't happy :mad:
White with a hint of blue :)
YOUR BASKET
2 x KFA2 GeForce GTX 770 LTD OC 2048MB GDDR5 PCI-Express Graphics Card **WHITE EDITION** with FREE GPU Keyring £369.95 (£739.90)
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £269.99
1 x Seasonic 860w '80 Plus Platinum' Modular Power Supply £179.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £145.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x Corsair Vengeance C70 Midi Tower Gaming Case - Arctic White £94.99
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9) £89.99
1 x Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9B) £89.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £74.99
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £44.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack £25.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Single Pack £13.99
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Single Pack (CO-9050005-WW) £13.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - White £8.99
4 x BitFenix Alchemy 8pin PCI-E extension 45cm - White £6.98 (£27.92)
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - White £5.99 (£11.98)
1 x BitFenix Alchemy 8pin EPS extension 45cm - White £5.99
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - White £4.99 (£9.98)
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - White £4.49
4 x BitFenix Alchemy 2pin I/O extension 30cm - White £3.95 (£15.80)
Total : £2,045.26 (includes shipping : £24.45).
You need a board, the Gigabyte OC is on offer and basically the best thing since sliced bread.
With the nice low profile RAM maybe pick a nice air cooler instead of the H20 1220
Also the Samsung EVO SSD is a newer generation product and has better write speeds.
YOUR BASKET
1 x Gigabyte HD 7990 6144MB GDDR5 PCI-Express Graphics Card £499.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM £269.99
1 x NZXT Phantom 820 Enthusiast Ultra Tower Case - White £199.99
1 x Silverstone Strider Gold Evolution 1000w '80 Plus Gold' Modular Power Supply (ST1000-G) £179.99
1 x Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard £167.99
1 x TeamGroup Vulcan ORANGE 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLAD316G2133HC11ADC01) £119.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £84.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £64.99
1 x Thermalright Silver Arrow SB E Extreme CPU Cooler TY-143 Fans £53.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £1,682.98 (includes shipping : £20.10).
