Hi there,
This is my second spec thread, I asked for one back in May 08 but never built it because I bought a car instead. Now I get my loan in 2 months time and will be buying a new PC/Htpc
I think I am up for building one, or I might just buy one of the pre-built ones so its got guarantee/warranty
I've never built a complete PC before, BUT I have replaced some parts on current pc due to failure or ineed of upgrade, PSU, RAM, HDD, Custom made CPU fans, custom HDD Fans.....
So tell me, have I pretty much built a PC?
Here is my previous spec back in MAY '08 ........
http://i6.photobucket.com/albums/y245/bon72/spec5.jpg
I got a new budget now, much lower than the 1st spec (£1000)
New budget around £600
I need something decent and will last over 6-7 years or so
The computer is going to be used for;
I also want:
HMDI outs so I can hook it up to 50" plasma TV @ 1080p
HTPC Case such as Antec Fusion
As for primary screen, back in May 08 I was looking at Samsung 245b (£200 things) and the HAZRO screens, if any of you remember which one I am talking about.
Whats good these days? I want 24" Screen budget is separate, £150 to £250
* I noticed in recent specs, people suggest the amd phenom..... so I guess the q6600 thing is old now....?
** I got a Samsung 1TB HDD, so if you could suggest a primary HDD that would be cool. Would another Samsung 1tb be good?
*** I forgot to add, I am really into HTPC, so one of the Antec Fusion HTPC Cases is probably what I want.
- Multi-tasking, a lot.
- Auto Cad
- Photoshop
- Internet surfing
- Playing HD and Bluray Movies (downloaded, not bluray disc so will not need blue ray drive)
I also want:
Thanks
