Spec me a build - £750 help needed
11 Nov 2012
Staffordshire
Hi guys,
A co-worker is looking to build a computer with the total budget of £750. I want to ensure they get the best parts they can for the money, so any help is very much appreciated.
They need, monitor, mouse, keyboard and everything else including the tower. If you can "skimp" on the peripherals and get the best components, this would be preferred.
They don't need an OS, as they will be using Windows 8 trial to begin with to ensure they get the best parts they can.
Monitor needs to be 23" / 1080p.
Finally, they did mention they would prefer an AMD build, thinking 8320 might fit the bill here?
Your help is very much appreciated so that they don't buy the wrong parts, or I recommend the wrong parts. The budget is set in stone and if we can get them a great gaming system, that would be awesome as it will be their first one. They will be buying from Overclockers also. :)
