Spec me a build please - £1500 - 1600
19 Jul 2010
Belfast, Northern Ireland
It's that time again... seems so long since the last time I was considering building a PC but here we are. Looking for a Bitfenix Prodigy M Build for gaming, red and black theme and custom wc loop (limiting the choices already :p). I don't need an OS, monitor or peripherals and would like an SSD (was thinking 500gb evo :p) and preferably 3TB HDD. Thanks in advance :D
You won't get a custom loop in a Prodigy M, I'm afraid. Could I interest you in a Parvum?
YOUR BASKET
1 x Parvum Systems S1.0 MicroATX Case - Black with White £129.95
Total : £138.65 (includes shipping : £7.25).
Even if your case can fit a custom loop, though, your budget will be tight to say the least with a 500gb SSD in there too.
This is the itx version and so this was the sort of loop I have been eying
Why not go for the same as he has, but with a GPU
YOUR BASKET
1 x MSI Radeon R9 290 "BF4 Edition" 4096MB GDDR5 PCI-Express Graphics Card £329.99
1 x Asus Z87 MAXIMUS VI IMPACT Intel Z87 (Socket 1150) DDR3 ITX Motherboard £205.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £169.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £149.99
1 x OcUK Tech Lab - XSPC D5 Vario Pump & XSPC Acrylic Tank Reservoir Value Combo £99
1 x EK Water Blocks EK-FC R9-290X - Acetal £79.99
1 x BitFenix Prodigy Mini-ITX Cube Case - Midnight Black £69.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
1 x EK Water Blocks EK-Supremacy - Acetal £49.99
2 x Patriot Viper 3 "Venom Red" 4GB DDR3 PC3-17200C11 2133MHz Single Module (P34G211UR) £37.99 (£75.98)
1 x Hardware Labs Black ICE Radiator GTS-Lite 240 £37.99
1 x BitFenix Solid Front Panel for Prodigy Case - Black/Red £12.98
3 x Alpenföhn 120mm Wing Boost Plus PWM Fan - Red Clover Edition £12.95 (£38.85)
1 x BitFenix Prodigy Window Side Panel - Black £9.95
1 x BitFenix Alchemy 24pin ATX extension 30cm - Red £8.99
2 x Mayhems X1 UV Red Premixed Watercooling Fluid 1L £7.99 (£15.98)
8 x EK Water Blocks Adapter G1/4" 45 degrees - silver £5.99 (£47.92)
1 x XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Clear £5.99
1 x BitFenix Alchemy 8pin EPS extension 45cm - Red £5.99
2 x BitFenix 6+2-Pin PCIe Extension 45cm - sleeved red/black £5.99 (£11.98)
8 x Monsoon 16/10mm (ID 3/8 OD 5/8) Free Center Compression Fitting - Black Chrome £5.45 (£43.60)
Total : £1,621.15 (includes shipping : £20.10).
I can't promise it will be an easy build. because it wont be.
