Spec me a build please
7 Oct 2004
Okies, its been awhile since i upgraded my system, going on near 3 years now, and im kinda outta touch with whats good and whats not etc etc, i know there is an entire new tier of CPU's and GPU's etc out there,
My system is used for gaming, everything from MMO threw to FPS,
So instead of trying to wade threw everything out there and work out what works with what and what doesn't, im gonna ask you guys who are more then likely a lot more up-to-date than me.
My price range is £1200-1500
I was looking at an SSD for primary boot, and use a standard 7200RPM disc for the main system, but is it really worth it.
CPU, im looking towards intel if poss
GPU, Nvidia, ive always used Nvidia, its a personal preference.
The new system will be running Windows 7 64bit.
I do have a current 1Kw PSU ( PC Power and Cooling ) the current system will be given to family to use, so i could always keep this PSU, or it maybe cheaper to replace it,
My only concern is monitor, now i haven't allowed for this in my pricing, as it will be separate, but i see these 120Hz monitors seems to have reports of no ghosting from faster moving games, the monitor wont be used for 3D ( as i cannot use 3D due to eyesight problems ) can the monitor run in 120Hz mode all the time to stop ghosting, if so whats the best one to go with?
Thanks
hello.
Your basketProduct Name Qty Price Line Total
OcUK Value GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card with MAFIA 2 £223.24
(£189.99) £223.24
(£189.99)
Intel Core i7 950 3.06GHz (Bloomfield) (Socket LGA1366) - Retail £217.36
(£184.99) £217.36
(£184.99)
Iiyama ProLite E2410HDSD 24" Widescreen LCD Monitor - Black £146.86
(£124.99) £146.86
(£124.99)
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard £144.98
(£123.39) £144.98
(£123.39)
Patriot Viper 6GB (3x2GB) DDR3 12800C8 1600MHz Low Latency Triple Channel (PVT36G1600LLK) £111.61
(£94.99) £111.61
(£94.99)
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) £111.61
(£94.99) £111.61
(£94.99)
Coolermaster CM-690 II Lite Dominator Case - Black £58.99
(£50.20) £58.99
(£50.20)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £44.99
(£38.29) £44.99
(£38.29)
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
(£11.91) £13.99
(£11.91)
Sub Total : £913.74
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.25
VAT is being charged at 17.50% VAT : £161.87
Total : £1,086.86
your psu will be plenty for this build, including any desires for sli too.
120hz monitors are for the 3D glasses from nvidia, so a normal 60hz is what your after, the 24" above will be a good match with the GTX470.
theres a 60gb SSD for windows and your most played games, and a 1tb harddrive for storage.
