- 17 Jan 2006
Just before my son was born, I took the opportunity to build myself a PC, knowing it would be a good long time before I would be able to build a new one.
My boy turned 12 in January and I'm still using pretty much the same PC - I changed out the graphics card when my original died and that's about it.
The current spec:
i5 2500K
Gigabyte Z68XP-UD3P
32GB Crucial DDR3 PC3-12800
GTX 1660 Super
and a bundle of hard drives which I've amassed over the years.
Impressively, this PC still largely runs everything I throw at it (I game at 1080P and will continue to do as as I will be keeping my existing monitors (2 x Samsung S24E200) but it is starting to get a little long in the tooth and I want to build a new PC - budget somewhere about £1,000 ish.
It will be used for work, long days of InDesign and Photoshop, along with office tasks, so a lot of RAM is important; and gaming - I tend to play lots of FPS, driving, etc etc, so good gaming performance is important.
I'd really like to go with the Lian Li Lancool 205M Mesh in white, as I like it looks and it'll (just about) fit on my unfortunately narrow desk. A little RGB would be nice if possible without sacrificing performance for the money.
I don't need a keyboard or mouse as Ill use my existing ones and I don't need wifi on the motherboard if that saves me anything.
Can anyone give me any suggestions as a starting point for the best bang for my buck but with consideration of longevity I'd like a bit of an upgrade path so this system can last me a good few years.
The current spec:
i5 2500K
Gigabyte Z68XP-UD3P
GTX 1660 Super
